Can I add a bluetooth card to this machine
there is a bluetooth port but no card blue tooth ant sign above F1 but no function switch icon at f2 or anyware else can I still upgrade this machine?
Esta é uma boa pergunta?
robert, enter the service tag from your computer on this site. It should provide you with a list of components and options for your individual computer. Hope this helps, good luck.
Esta resposta foi útil?
Isn't a bluetooth already there in Dell's build up. I have a Vostro and bluetooth is built-in inside. Latitude is an old model, I suppose, you have to look into Dell Store for sure or I think a local technician may also help you out.
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 426
3 comentários
the laptop didnot have blue tooth when i got it i did inspection of it and it has the port just want to know if i can upgrade it
por robert
Do you have the slot labeled WPAN/UWB/FCM on your motherboard?
por oldturkey03
yes port has small blue wire at it
por robert
