Ir para o conteúdo principal
Lançado em março de 2006, identificado pelo modelo D620 no bisel do teclado.
Computer will not go past "Start Windows Normally"
I got my farther the Dell D620 to start him off with, he was online when the battery went dead and turned off. I plugged it in and started it back up, it went to the "Start Windows Normally" screen, I pressed "Enter" to do this and it just keeps going back to the same "Start Windows Normally" screen after it goes to the window screen to load up. I have noticed a "Blue square" with white writing in it flashes for less than a second before going back to "Start Windows Normally" screen, it is to fast for me to read. How can I get past this? (if I can)
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Have you tried booting to safe mode, to see if it will boot?
Esta resposta foi útil?
Pontuação 0
1 comentário:
I did with no effect, I've just tried start up with F8 (starting up at a safe point) and it has worked. Thank you for commenting.
por
Adicionar a sua resposta
Gavin Hogan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 20
Ao todo: 1,023
