Ir para o conteúdo principal
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
121 Perguntas Visualizar todos
How to get USB 2.0 on this model?
Please inform whether it is possible to get USB 2.0 via extension card, and if so, where to get one.
There are people claiming that hard-wiring inside the machine effectively will prevent any buscard solution. Also, there seems to be restrictions on buscard types working on this model.
I'll be ever so grateful for tips, as info so far seems both contradictory and confusing.
Newcomer
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Solução escolhida
I've never tried one of these, but you can get a Firewire to USB2 converter:
http://cgi.ebay.com/Male-Male-USB-2-0-Fi...
Esta resposta foi útil?
Pontuação 4
4 comentários:
Agreed +
por
yeah good workaround
por
This is a male to male.. just pointing that out
por
Yeah, you're logic board won't be able to handle USB 2.0, so it's a no go.
Pontuação 0
I'm pretty sure theres a PCMCIA port on your PowerBook. Try this:
USB 2.0 PCMCIA Cards
Pontuação 0
3 comentários:
This is a PowerBook, not a MacBook, all MacBooks have usb 2.0
por
I meant PowerBooks. I think none of the MacBooks have PCMCIA card ports
por
You should update your answer to say PowerBook instead of MacBook then... ;)
por
Adicionar a sua resposta
BELarsen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 724
