Ir para o conteúdo principal
Modelo A1419 / Final de 2013 / Processador Core i5 de 3,2 & 3,4 GHz ou Core i7 de 3,5 GHz, ID iMac14,2
screen hinge loose tilts
Is possible to tighten the iMac screen hinge without completely dismantling the computer. some claim a plastic card pushed in above hinge with release a clip allowing asscess to torx screws ?
Esta é uma boa pergunta?
Pontuação 5
2 comentários
Any news on this?
por Compartilhar
I made a fix for this. www.themachack.com
por Compartilhar
Adicionar um comentário
2 respostas
Solução escolhida
Simple solution: A rubber crutch tip placed between the monitor and the stand holds the monitor position securely and can be very easily adjusted in about 5 seconds. Cost: $0.29.
Esta resposta foi útil?
Pontuação 6
3 comentários:
Simple fix: A rubber crutch tip to support the screen is infinitely adjustable. Mine has been in place at least six months with absolutely no problem.
por Compartilhar
Yep,worked a treat
THANKS
por Compartilhar
What is a rubber crutch tip? Is it the piece that goes at the bottom of the pole of crutches? I’m trying to imagine how that would work.
por Compartilhar
The newer iMacs have a newer foot design.
Your idea of a plastic card was the means to gain access to the foot screws to replace it for a VESA mount on the early '12 and older units. Sorry won't work here.
Here's some background: iMac 27" stand removal.
Given the age of your system I would try going to Apple for repairs.
Pontuação 2
Adicionar a sua resposta
scoot será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 70
Ao todo: 15,375
