Ir para o conteúdo principal
O HTC One SV é um smartphone Android elegante com capacidade 4G LTE que combina um som de alta qualidade Beats Audio™
Power Button Works Intermittently
My Power Button on my HTC One SV is slowly becoming non-functional. at first it started with pressing the power button a couple times to bring it out of standby, then 3 times, then it started to need to be pressed hard. Now it won't work using my fingers, i have to grab something and push the power button in farther than my fingers could. is there a repair fix? or Contact HTC?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
same thing happen to me I sent the phone to HTC and they sent it back and said they did not have the parts for power switch cost me 56 bucks to ship with insurance , a rp rep called me a month later and said you are just out of luck you have to buy a new phone and they were done ,i got a micro switch and installed it on the board "wrong switch" but the phone works great not I don"t have a button that makes it look pretty on top now but better than HTC answer . Good luck to anyone who has a HTC one S V the power switch is not very good design and it falls apart easy in 1 week my new universal micro switch is stout and is working great ....
Esta resposta foi útil?
Pontuação 0
I fix mine :)
I found the fix here
Solution: compressed air and/or alcohol
I actually combined both ... and used a Deo Spray :)
Hope this helps others too.
Pontuação 0
Adicionar a sua resposta
jfinley2003 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 3,101
