Ir para o conteúdo principal
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
121 Perguntas Visualizar todos
Internal keyboard and trackpad intermittently not working
Sometimes on boot up trackpad and keyboard will not work although a remote mouse plugged into USB port works ok but the keyboard still does not work.
If unit dropped about 3 inches on carpet (naughty i know ) works again, although sometimes stops working again whilst in use.
I suspect a loose cable/plug. Any ideas?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
trackpad socket on logic board broken away from soldered joints
por
Adicionar um comentário
1 resposta
Solução escolhida
Yep, if you drop it and it works then a cable will be loose. Basically, make sure all the connections to the logic board featured in this guide are in properly.
Esta resposta foi útil?
Pontuação 1
1 comentário:
found trackpad socket had broken away from logic board on soldered joints
por
Adicionar a sua resposta
Petethefish será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 3,261
