Ir para o conteúdo principal
Uma linha de discos rígidos externos da Western Digital, com um design que lembra livros de capa dura. Disponível em várias edições, desde a Essential até a Premium e a World Edition.
Blue Screen of Death
Have a 3TB My Book, has been working fine, then all of a sudden as soon as it is plugged in i crashes my system and gives the Blue screen of Death.
Have tried it on other systems and it does the same thing.
Really need help
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Download BSOD From Nirsoft.It`s totally free. Doesn`t install. Run immediately after BSOD. The error is highlighted. Copy d paste the culprit to your browser to find more info. Good luck getting rid of the enemy.
por Compartilhar
Adicionar um comentário
3 respostas
Pergunta mais útil
It sounds like the boot sectors are damaged (may even be a malware infection)
I assume you have a Windows system here:
Do you have a friend that has a Mac?
What you need here is to use a disk utility that won't alter the drive to a Mac readable drive but one that can fix the boot sectors for your Windows based drive, not many Mac utilities offer this. I would recommend your friend to get Drive Genius. If at all possible run a good antivirus program (with the latest def files) on the Mac on the drive before trying the drive back on your Windows system. Also check your Windows system fully in case it has something on it.
You could also try Linux and run on the drive repair & antivirus tools available with it as well.
Esta resposta foi útil?
Pontuação 1
Hi,
I have had the same issue. Your W.D. Unit is faulty. You need to replace it, under warranty I hope.
Pontuação 1
Download BSOD From Nirsoft.Is totally free. Doesnt install. Run immediately after BSOD. The error is highlighted. Copy and paste the culprit to your browser to find more info. Good luck getting rid of the enemy.
Pontuação 0
Adicionar a sua resposta
Vaughan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 1,190
