Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Charging battery directly without plugged in
I know my question is weired but i want to know of a way to charge the battery of iphone directly as the power IC is not working and it is not charging with cable.
I am in a country where no one change the power IC or repair it. I have spend lots of time searching but was unable to find anyone. It is a water damaged phone. It used to charged when switched off but now its not even charging when off.
I remember we use to charge the nokia battery with external charger and then put it back on, so any solution that can work as i do not want to just through it away.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Zubair , it could be a problem with the charging circuit, but I'd start witha new battery and then the dock connector. If that fails check all the charging components. This could be caused by a failed/damaged charging coil. Check for any physical damage, or if you have the knowledge and tools, check for function. You want to start by checking 3 inductors. For that, of course, you need a multimeter, or at least an ohm meter, to check for continuity. I hate to refer to those as fuses, but they most certainly control part of the charging circuit. First one is reference designator L3, it is a FERR-120-OHM-1.5A inductor. L4, right below it , has the identical value. Next would be the charger inductor L28 2.2UH-1.8A-155MOHM. All of these are pretty much available at mouser. com or digikey.com. Check the Diode D604, located just above L28. Hope this helps, good luck.
As for charging the battery separate from your phone, do keep in mind that it is easy to overcharge it. This could lead to some rather hot and explosive battery. Yes you could build a charger but make sure that you include a PMW IC to prevent overcharging. Something like this could work for you.
Esta resposta foi útil?
Pontuação 1
Charge battery off another phone!
Or try searching the computer room Nottingham on Google they specialise in the repair you need
Pontuação 0
1 comentário:
Thank you. Just for the information. I still have this phone with me and i am not using it. I am now using Iphone 5C and end up having almost the same issue with 5C. :-(
I am coming to UK in few months and hopefully will get it repaired from there.
Thank you for the information "CON" & "OldTurkey"
por
Adicionar a sua resposta
Zubair será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 5,736
