Ir para o conteúdo principal
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
208 Perguntas Visualizar todos
How to open top lid on MayTag Bravo Washer 300 series
My MayTag Bravos washer, model MVWB300WQ0, has a coin inside. I need to know how to open the top lid to access the drum.
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
1 resposta
Solução escolhida
fanniealambert, check this photo guide it shows how to remove it. Get the putty knife to depress the clips....Hope this helps, good luck.
Update (03/07/2022)
Just become aware of the fact that the link no longer works. Here are the written instructions on how to access the components, which includes removal of the Lid etc.
Component Access
Esta resposta foi útil?
Pontuação 1
2 comentários:
this forum is closed
por
@Yoan Labelle Take a look at the attached document. It should have all the info needed.
por
Adicionar a sua resposta
fanniealambert será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 19
Últimos 30 dias: 70
Duração total: 20,612
