Which cable controls touchscreen?
Just replaced digitizer, all went well, booted fine, but touchscreen not responding. Do you know which cable controls touchscreen?
Esta é uma boa pergunta?
Ribbon #2. It can be kinda hard to get in place just right- make sure you hear it click.
Esta resposta foi útil?
and when i unglued the touch screen glass of touch screen ourselves ? What should I do ? when opened, can see perfectly bonded touchscren cable itself and not make contact with the touchscreen glass .What should I do ?
I hope you purchased the right part, Apple in their infinite wisdom made the connectors slightly different from 3G to 3GS.
It could also be that you bought a faulty part, the failure rate from eBay is quite high because the parts are usually factory seconds,
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 12
Ao todo: 12,605
