Ir para o conteúdo principal
Fruta saborosa. Boa fonte de potássio. Amarela.
How To Teardown And Possible Poison?
This device is extremely treacherous! It has a given me many issues during tear-down for my son. First off hows a way to guarantee the initial snap at the top to begin tear-down and also what is this brown device at the bottom? Is it poison because my son refuses to ingest it.
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
5 respostas
Solução escolhida
Learn from the Professionals! Observe a monkey. To open a banana: Ignore the handle-like stem. Turn your banana upside-down and focus on the nubby, pointed tip at the opposite end. Pinch this tip between your first finger and thumb — this will split the skin of the banana cleanly, allowing you to peel it back. https://www.youtube.com/watch?v=sf-yWxPm...
Esta resposta foi útil?
Pontuação 4
Level up your SNAPBACK skill by wearing trendy sun visors while thumb wrestling with your friends.
Pontuação 2
Snap from the bottom, you get better results every time. And yes the brown spots are poison. Avoid at all costs.
Pontuação 2
If you split from the bottom it is easier to flick the deadly brown spot from the device before removing the protective covering
Pontuação 2
Don't broke the white motherboard inside when you open it !
Pontuação 1
Adicionar a sua resposta
Jay Kizzle será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 28
Ao todo: 1,017
