Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2375 Perguntas Visualizar todos
Pergunta encerrada
Should I try replacing the motherboard as a novice?
I was told here that because my wifi is greyed out and my camera flash is dimly lit since my phone got wet that my motherboard/ logic board might be corroded.
Being a relative novice in the iPhone repair world (I have replaced the battery and the wifi antenna) should I attempt this repair?
If I should proceed, where would be the best place to get an OEM motherboard/ logic board since they don't seem to sell them on IFIXIT?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Only you can decide wether or not you feel comfortable proceeding. With that being said, here are a couple of points to consider:
1. Have you viewed the appropriate guide, such as this one for Repairing Liquid Damage?
2. Do you have the appropriate tools and working space? If not, can you, or will you acquire what you need?
3. For iPhones, the logic board is essentially the phone, that's why iFixit doesn't sell them. Purchasing a reliable logic board by itself can easily cost you almost as much as a new device. However, trying to properly address the potential liquid damage would cost far less.
4. I have found that eBay tends to be the "best" source for logic boards, provided that you are willing to tread carefully. If you just buy the first one that you find, you may be out of luck. If you still want to get a new logic board, make sure that you only purchase from a reputable source, and be sure that you have read and fully understand the description, condition and implications of both before proceeding with a purchase.
Good luck to you!
If you found this helpful, please up-vote or Accept Answer.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thanks Joshua! I looked over the liquid damage damage guide and I will give that a try. I appreciate your thorough answer. I will let you know how it goes!
por
Sounds good! Thanks!
por
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 100
