Ir para o conteúdo principal
Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
330 Perguntas Visualizar todos
Add SSD to a Fusion drive iMac
Hi
I have a 3TB Fusion drive and I just bought a 1TB 2.5" SSD (Samsung EVO 840).
I want to add it to my iMac as my boot disk and make the Fusion as storage.
Is there any way to do so without removing the 3TB HDD and break the Fusion?
I saw this product but than I'll have a useless Blade 128GB SSD:
http://www.ebay.com/itm/SATA-Blade-SSD-M...
P.S
My iMac configuration is:
27-inch, Late 2012
3.4GHz i7
32GB RAM
NVIDIA GeForce GTX 680MX
10.9.1
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Anyone?
I'm the first one to upgrade a fusion to big sdd?
por
Adicionar um comentário
3 respostas
Solução escolhida
Only some models have blade connectors are your certain yours is one that does?
Have you figured out where and how you will mount the SSD there's not a lot of room in there.
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Pontuação 0
3 comentários:
I'm sure.
In your link it shows that every late 2012 27" iMac has it and mine has a fusion drive so it uses it now, right?
por
Yes - my mistake in reading, all 27" models do have it - but there's not a lot of room, how/where are you going to mount the non-blade SSD?
por
I will find a way to fit it in.
In the worst case I will remove the SSD casing.
So there is no way to connect it without removing something?
por
Pergunta mais útil
i did it back than..
I now have 1TB SSD + 8TB HDD (because the original 3TB died).
I used the blade to sata converter + a cable that splits the power from the HDD to both drives.
The SSD fits behind the HDD
http://www.ebay.com/itm/SATA-22-Pin-Male...
Pontuação 3
You have two storage device ports internally. One is a SATA (HD) and the other is a custom Apple blade SSD connector.
Pontuação 1
1 comentário:
How to set up a fusion drive on the model:
https://support.apple.com/en-us/HT202574
por
Adicionar a sua resposta
Oudy Even Haim será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 3,623
