Ir para o conteúdo principal
Repair information and disassembly guides for Sony PlayStation controllers.
966 Perguntas Visualizar todos
Pergunta encerrada
Will a different V and mAh replacement battery kill my PS3 headset?
I have torn down my official PS3 headset to change the battery. The original battery is a 3.7V 1350mAh battery. Replacement ones are 4.2V 1800mAh. Will that burn / grill / kill my headset?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Ben Hamel, the mAh will not but I'd be a bit leery about the higher voltage. It may be okay for the controller to handle it, but you are looking at a 15% voltage increase. I'd try to match the recommended voltage a bit closer. You might get a bit of a better answer if you can tell us exactly which headset you own.
Esta resposta foi útil?
Pontuação 0
1 comentário:
The headset I own is this one : http://m.us.playstation.com/ps3/accessor...
The original battery was an LIP 1472 Li-Ion.
por
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 715
