Ir para o conteúdo principal
O HTC One X é o primeiro celular da HTC a ser equipado com um processador quad core, lançado em abril de 2012.
"No Sim detected" problem
The Sim card detection suddenly stopped. Whatever service is put in, no SIM card detected.
What might be the reason?
What is the Fix?
Thanks,
Ravi
Esta é uma boa pergunta?
Pontuação 10
Adicionar um comentário
6 respostas
Pergunta mais útil
I found that my issue was that there is a piece of metal at the bottom of the SIM card slot that when you put it the sim it connects with a sensor that tells the phone a sim is inserted. But the issue is the metal cage does not cover the full sim area and the metal arm can dislodge at the bottom and doesn't connect. I had to take the back off and push the arm back in alignment to have it recognize the sim again.
Hope this helps,
Esta resposta foi útil?
Pontuação 5
A simple solution/work around to this issue involves placing a small piece of tape or paper behind your phone's SIM card and sliding it into place as normal, don't force it, it should slide in smoothly with no extra force needed. If done correctly, this may make your SIM card fit more snug into the SIM card tray and enhance the SIM card's connection.
Pontuação 2
I have this Problem after "NO" remedy finaly went to shop who change the Jacket which cost me a good amount
Pontuação 1
Hi,
I had the same problem and I've found a solution of that problem in youtube. Have a look it might help you as well.
https://www.youtube.com/watch?v=gfNUu4Dj...
Thanks
Pontuação 0
Geniiioooouuussssss!!!!! Thanks a lot!
Pontuação 0
1 comentário:
Which answer helped you?
por Compartilhar
SIM card in my phone but
No SIM card shows me
Please halp mee
Pontuação 0
Adicionar a sua resposta
Ravi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 33
Ao todo: 24,550
