Ir para o conteúdo principal
Repair guides and support for cars produced by the British automotive manufacturing company, founded in 1903.
change indicator relay on Vauxhall Combo
My right hand indicators don't work properly and I have been told that it is probably the relay. And wouldn't you know it, apparently it's a real pain to replace? Because of its location. Apparently it is behind the battery and something else. Any help please.
Esta é uma boa pergunta?
Pontuação 2
6 comentários
What year is your Vauxhall?
por
It's a 2005 55 plate
por
Does that relay also control the reversing light?
por
any more my light do not work 1.9 vauxhall combo reg 04
por
I have no flasher and hazards . Fuse and relay is ok on vauxhall vivaro 2004
por
Exibir mais 1 comentário
Adicionar um comentário
2 respostas
Pergunta mais útil
Geoff Heyes, the relay is located under the hood, adjacent to the battery. You should see a black weather sealed box. You will need a long extension and a Torx ( I read a T20) socket to remove the cover. The indicator relay is the large yellow one.
information from here
Esta resposta foi útil?
Pontuação 2
6 comentários:
That's a great help.
Many thanks.
Geoff
por
You are welcome, best of luck to you.
por
This was really helpful to me many thanks
por
Hello,
Thank you, this is super helpful, even now!
If you're able, do you have a replacement source for the info? I have the same issue with my indicators, and want to figure out what relay to buy...plus my wipers won't go max speed anymore, which I think is linked to one of these also in the rear fusebox. The manual I have doesn't explain any of them, sadly.
Many thanks in advance!
por
@larn what exact year, model etc. is your Vauxhall? Let's see what we can dig up :-)
por
This relay is located near the BCM module. It is located under the plastic that covers wiper linkage and motor. There is another plastic that covers BCM module and relays near it.
Pontuação 0
Adicionar a sua resposta
Geoff Heyes será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 16
Últimos 30 dias: 73
Ao todo: 33,810
