Ir para o conteúdo principal
Pergunta encerrada
Why are the fans running at full speed?
The fans on my 17" Macbook Pro are running at full speed regardless of the temperature of the computer. Even if I turn on the computer when it is stone cold the fans almost immediately start racing.
When I look at the CPU temperature sensor I see massive fluctuations in the readings. Within a 5 second timeframe the temperature will jump from 210 to 180 to 196 then back to something in the 200s.
Any suggestions?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I have reset the SMC, but there has been no improvement. The fans are still at top speed.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Lets try a different direction here:
Download a temp & fan monitoring app like Temperature Gauge Pro, others will also work here I just like this one. See what it tells you Post a screen shot so we can see.
Esta resposta foi útil?
Pontuação 2
Try resetting your System Management Controller (SMC) take a look at this link, http://support.apple.com/kb/HT3964?viewl...
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 9,584
