Ir para o conteúdo principal
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
224 Perguntas Visualizar todos
Soldering pad for battery ripped off
So I had to repair my iphone 2g and all the problem is is that the battery needs to reconnect. And those shiny soldering pads where the solder sticks to are ripped off. I tried aluminum foil glued to the board but it don't work. I have the pictures but I don't know how to show you guys. Any help will be appreciated.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
Edward, here is a quick and dirty guide on how to add images. As for connecting your battery, I added two images that will show the battery ways. It will help if you can add images of your logic board, front and back, since it may be more visible and easier to follow. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
solder pads are "landing strips" that are attached to the actual copper traces. If you've damaged the solder pads, you have to build jumpers to link the battery connector to the next component on the circuit---the iPhone 2G pre-dates my knowledge of this field so I can't tell you where to connect a jumper
Pontuação 1
Adicionar a sua resposta
Edward será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 556
