Ir para o conteúdo principal
Potente laptop de entretenimento da HP
DC Power Jack does not function.
The main power connector has gone, basically when I plug the power jack into the socket it doesn't seem to connect properly internally, therefore wont charge the battery. If you fiddle with it you can get it to connect enough to charge the battery but this fix is becoming more and more of a rarity. I think I need to replace the jack but don't know how...
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
At first I thought this was one of the plug in type motherboard connectors and was easy to get to...seems you'll need to take the motherboard out, desolder the old jack and replace it. If its just a case of cracked solder on the feet of the jack you may just be able to reheat the existing solder to stabilize the jack. I used a heat gun on similar repairs as it gets all the pins/feet loose at the same time, you just need to protect the surrounding components from the heat. A quick google shows several on line disassembly manuals and youtube videos that would help, or you can click on the guides to the right under the picture.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Cyndi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 14
Ao todo: 562
