Glass Broken on Lumia 625
I need to know if the Nokia Lumia 520 screen replacement guide is the same for the Lumia 625?
Cheers Mark
Esta é uma boa pergunta?
Cheers Mark
Mark Dyall, not quite, but almost. Check this video as well as this one. Those should provide you with enough guidance to get the job done. If you need to, go to the device page, scroll all the way down to support documents and click on the blue link. That will download the service manual. Hope this helps, good luck.
Esta resposta foi útil?
I've just done a glass/digitiser replacement on my daughter's phone (625). Not too painful actually although getting the top of the glass to unstick where the ribbon cable is attached took a while. Obviously didn't have to be _too_ careful with removal as it was smashed already! The replacement glass/digitiser had sticky on it already so a pretty straight forward job. Hardest part was dust removal before sticking down the new glass.
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 27,376
