Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1204 Perguntas Visualizar todos
Steps to upgrade hard drive, including backing up and restoring?
Macbook 4.1 13" 2008 White - MacBook "Core 2 Duo" 2.1 or 2.4 GHz
I'm upgrading my original MacBook HD from 128GB to 500GB.
How and when do I back up and then restore my current hard drive.
Do I need to format the new disc and do I need partitions and if so, how do I do that.
Thanks, Mikie
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Yes - you should backup - Ideally you always keep a current backup.
Yes - you have to format the new drive GUID single partition in order to install the OS
You boot to your install disk, format the new disk using disk tools, do the install, after installing you restore from backup. Or - if you have an external case you could put the old drive in it it, skip the backup but after the install use Migration Assistant to transfer your old apps and data to the new drive.
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Pontuação 1
5 comentários:
I do have an external hard drive that I just bought to assist me in this process. I was told to do a time machine back up. Then after installing the new hard drive to do a restore from time machine????
Also, if I am going to do a restore..... do I still need to load my operating system from my original start up disc? Cause since then I have upgraded to Mac OS X 10.6.8. I am not sure if that is Leopard or Snow Leopard. Which disc would I use to reinstall my operating system. Or do I have to do that at all cause I am doing the restore from time machine.
Please accept my apologies for not being very knowledgable about this stuff.
por
I believe you have to install your old OS then upgrade (without transferring any data yet) Once you finsih the install/update of your new OS restart holding down the Command and R keys to start the computer from the Recovery system. The Recovery menu that appears includes the option to restore from a Time Machine backup. OR follow one of Dan's solutions below. There are at least three different ways to accomplish most tasks on a Mac.
por
wow, sounds involved.... but i will give it a shot. The hard drive I bought is a HGST, 500 G with SATA II. It is 3.0 as you stated, but I heard from some macbook users with the same model that it worked with their system that had 1.5 gb/s. I hope that is correct.
por
What OS disks do you have? If you only have the recovery disk then you'll need to use them. If you have the installer image files you can run it off of your running HD to prep the HD and install the OS. It's just a matter on which you have and how you connect your HD to your system.
por
Give HGST a call just to be sure your HD is OK, As each manufacture updates their drives it could be OK here. If it's a newer version you may have an issue. Don't forget to update the EFI/SMC firmware first.
por
Pergunta mais útil
First you can upgrade to almost any size (GB/TB) HD that is 2.5" and only 9.5mm high. So your options here on what to get is not limited to a 500GB drive. With that said you do have one issue you must watch out for as your system uses the older SATA I (1.5 Gb/s) interface. You must make sure what ever drive you get can run at this lower I/O speed. Many HD's today are SATA III (6.0 Gb/s) or SATA II (3.0 Gb/s).
If you really want some zip I would recommend a hybrid HD (typical HD with a SSD cache). These drives are called SSHD. Seagate makes one that should work for you as it has SATA I/O speed auto sense. But you do need to make sure the EFI firmware is up to date. Before doing anything follow this Apple TN on updating EFI & SMC firmware updates for Intel-based Macs. And follow this IFIXIT guide on how to replace your HD MacBook Core 2 Duo Hard Drive Replacement. Here's a vid on the process Apple MacBook Hard Drive Install
OK lets review the needed steps to save your current data and transferring it over to your new HD:
First you should get an external USB HD so you can backup your drive as an option you could also get an external case to house your current HD in (more on this later).
If you are using an older version of OS-X you may want to think about upgrading to the newest version your system can support. One issue here is the amount of RAM needed and also the versions of your current Apps. If you are still running any OS-9 apps then you will need to stay with OS-X 10.5.x (Leopard). If you are thinking about going to Lion You will need to up the RAM to a minimum of 2GB (I strongly recommend going to at least 4 GB) the max is 6 GB using one 2 GB and one 4 GB memory module. Also note you can't run any higher OS-X as you are limited to 32bit mode on this system and when you do buy apps you do need to make sure you get 32bit or 32/64bit combo apps. Be careful with updates as sometimes they are only 64bit versions now.
I do recommend first upgrading your RAM and the OS as the first step if you haven't done this yet.
OK, now the easy part ;-}
Once your system is stable with the new RAM & OS make a fresh backup onto your external HD. At this point you will need to have your new HD in hand and you will need a means to connect your new drive to your system.
If you have access to a second Mac system this could be faster as you could use a FireWire case to temporally hold your new HD and connect it to the other Mac (if it has a FireWire port) then using this system directly (or into Target Mode and then via a Ethernet connection to your system) prep and install a fresh copy of OS onto your new HD. Depending on what your second Mac is and the OS it has you might find this a bit quicker. Otherwise you will need to use the USB port to connect via the universal adapter cable (SATA to USB) for your system as your system has slow USB ports this will take a bit of time. You also will need to supply power for your HD externally as your system USB port can't support the load of the HD (more so when prepping it as well as installing OS or other software).
Prepping your new HD:
Yes you do need to partition & format it using Apples Disk Utility you will partition the drive (one or two partitions being ideal). Then you will need to format the partition(s). Here's a good writeup on the steps How to Partition Your Hard Drive on Mac OS X Snow Leopard. Don't let the OS version listed here worry you its the same steps in all of the versions of OS-X. WARNING! Make sure you don't alter your current HD settings! Next you will use the OS installer app (or OS DVD) to install the OS onto your new HD. Once you have the OS installed you should try it out. To do that go into the control panel and select it as the boot disk and restart your system if all goes well your new HD should be the first listed drive. As you are loading though USB it will take a bit of time to come up, get a cup of coffee and mellow out a bit. As your halfway through!
If you remember at the top I stated you could do without the backup HD (cheapest option). Here you will use your current HD as the backup. This is were you use an external USB case to house the new HD to prep it and then after you install your new HD you put you old HD into this case.
OK last software step - Moving your files over:
At this point your new HD is prepped and a fresh copy of OS is on it. Your next step is either migration or cloning. Migration uses Apple Migration assistant (the preferred way) and Cloning uses an app to replicate between the two HD's. The only wrinkle here is cloning requires a third drive as the boot disk and location where the cloning app is located as you can't have any files open on either disk you are cloning. Migration requires a second Mac to host the drive Heres a good writeup How to use Migration Assistant to transfer files from another Mac Here you will take your old HD out and place your new HD in the system. Then follow the section: Time Machine or other disk Your old HD is connected on the other Mac in Target mode in either a USB or FireWire case (FYI: Some cases offer both ports!) Then in section 7 select your old HD as the source from the other Mac.
Pro's 'n' Con's - Migration needs two systems but you end up with a fresh OS install. Cloning cares over all of the old system files over and you need a third disk as the boot drive. This could be a USB thumb drive.
Hopefully that answers most of your questions. I know its a lot here to read, doing it is much easier. Good Luck!
Pontuação 3
3 comentários:
I commented up above..... regarding the hard drive I bought. This sounds involved... but I think I'll give it a shot. So, when I reinstall I will install from my original discs, then upgrade. After that I will try to reinstall my data. Wish me luck.... Any more advice?
por
Take your time. It's not that hard a task there are just a few different ways as Machead stated you can do here. It's just about what you have access to and how much time you have to do things.
por
Thanks for the help! I'll let you know how it works out. I have the original startup disc. I look at it this way...... if it works great. If not, I buy a new macbook pro and clean my hard drive on this one and give it to my son...15 yr old. Then my next headache will be transferring my data from the old mac to the new mac. LOL
por
Adicionar a sua resposta
Mikie será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 6,840
