Ir para o conteúdo principal
A versão slim do clássico Xbox 360 com disco rígido de 250 GB e Wi-Fi integrado. O reparo requer ferramentas complexas de alavanca e ferramentas especiais.
E82 error code on 360 S
I have a E82 error code displayed and a Red LED light at the 360 S console. What should I do to fix it ? Tks
Esta é uma boa pergunta?
Pontuação 8
3 comentários
E82 solved - reheat cpu 350 degrees C / 5 minutes.
Working very well now.
por
my xbox 360 S keeps on showing red lights
can I have some help
por
it says E82 and I have tried to fix it but it still says it
what should I do?
por
Adicionar um comentário
1 resposta
Solução escolhida
Ben Ho, "E82 has been a common error on the slims for some time since release, E82 error is the GPU has overheated and come unseated from the main board. Try to turn the console on without a HDD in place. The HDMI cable also may be a reason so try to use a standard AV-cable. If the console still displays the error, then you may have to reflow/reball the GPU. Also, check with MicroSoft and see if it is still covered under warranty. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 7
5 comentários:
why is the xbox360 have red rinhg of death
por
@andrecious32 are you asking this as a general question? You just want to know why the Xbox360 was plagued by the RROD?
por
@David Garcia not sure about HHD but if you are ferring to HDD that stands for Hard Disk Drive. Here are the guides to work on your Xbox Xbox 360 S
por
That might be it. The problem I’m having is everytime I plug in an AV cable or a HDMI cable, the power button in front turns red@oldturkey03
por
How did you fix it?
por
Adicionar a sua resposta
Ben Ho será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 37
Últimos 30 dias: 106
Ao todo: 57,002
