Ir para o conteúdo principal
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
185 Perguntas Visualizar todos
How Do I Replace the Sceen?
I dropped my phone and it shattered the upper left hand corner of the glass. The crack traveled diagonally down the screen to the lower right hand corner. Most of the screen has become unreponsive to touch inputs as a result. How do I replace the LCD? If part of the screen is unresponsive, does it require something else other than a screen replacement?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Marty Semrau, there is a LG G2 LGD803, LG G2 VS980, and LG G2 LS980. I checked all the manuals and they are pretty consistent on the disassembly. Check for the how to disassemble it on the device page, scroll down to supporting documents and click on the blue link. that will download the disassembly guide. Remember that parts like speaker, camera, and others are glued to the frame, so these need to be carefully removed. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Marty Semrau será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 10,081
