Ir para o conteúdo principal
Released around 2010, the Dell Inspiron 15R N5010 is a 15-inch laptop with an Intel processor and dedicated ATI Radeon graphics card.
49 Perguntas Visualizar todos
I want to replace my graphics card
hi i have dell inspiron N5010 with the following configuration
System Model: Inspiron N5010
Processor: Intel(R) Core(TM) i5 CPU M 430 @ 2.27GHz (4 CPUs), ~2.3GHz
Memory: 5120MB RAM
Available OS Memory: 4982MB RAM
Card name: ATI Mobility Radeon HD 5470
Manufacturer: ATI Technologies Inc.
Chip type: ATI display adapter (0x68E0)
DAC type: Internal DAC(400MHz)
Display Memory: 2737 MB
Dedicated Memory: 502 MB
Shared Memory: 2235 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
i want to replace new grafics card 1 gb AMD Radeon HD 6630M is it possible?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Solução escolhida
gopi krishna, your " graphics card" is actually a chipset that is part of the system board, it cannot be upgraded.
Esta resposta foi útil?
Pontuação 2
Hi,
You can not integrate any additional card into your laptop motherboard.
Good luck.
Pontuação 0
The gpu is actually dedicated not integrated so maybe it can be change my advice will be to write to DELL as that is what i'm about to do because i have same product
Pontuação 0
2 comentários:
did you get any reply??
por
Did anyone find a fix for N5010 graphics card issues.
por
I had the same issue
Had my laptop reflowed .. it lasted a couple of yrs after that same problem
Then some repair guys from kolkata somehow changed it with a intel gpu for INR 4000 and it's working fine now.
Pontuação 0
Adicionar a sua resposta
gopi krishna será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 14,102
