Ir para o conteúdo principal
Stuck in continuous apple logo loop, turns off when cable removed?
Hi there.
My iPhone 5 (model A1429) will not boot into iOS.
When the power cable is connected, the iPhone boots up initially and displays the apple logo for ~3.5 seconds. Then it goes to a blank screen for another ~2 seconds and the process repeats (indefinitely it seems - at least at this point).
When the power cable is removed, the screen instantly goes blank again. Nothing happens if I press the power button when the iPhone is not connected.
I can get the iPhone into recovery mode by holding the home button before I plug it in, and then it stays on the recovery screen, not coming on and off like the apple logo was earlier. Again, when I unplug the cable it goes back to a powerless blank screen.
The iPhone is detected on iTunes in recovery mode and I have attempted to restore it, using both my MacBook and a Windows PC. Each time, it results in an error at the point when the iPhone appears to restart. I see Error 2001 on the MacBook and Error 21 on the windows PC.
I've updated to the latest iTunes version, restarted the computer several times, and tried different USB ports.
I was also able to get the iPhone into DFU mode, where the screen was blank—but it was recognized in iTunes as being in recovery mode. Just as before, the device will not restore, and I get various error codes across my Mac and PC.
I have since opened the device up and confirmed that the battery is securely attached to the logic board.
It is also worth mentioning that my iPhone is no longer under warranty.
At this point. my assumption is that the battery itself is dead, and won't hold any charge, which is why the device shuts off immediately after removing the power cable. Does this seem reasonable and should I order a new battery? Any other suggestions?
Many thanks,
Bradley
Esta é uma boa pergunta?
Pontuação 268
71 comentários
Any advice? many thanks
por
my friend replaced the battery but it still does it what do i do?
por
i have the same prob
por
Its just the problem with battery connector..take it to service centre..jst a minute away you are from fixing the problem.or either you can do it urself if you have knowledge to connect it properly.
por
basically its because one of the components on your logic board has burnt out i think, i mean i checked inside and it looked like one of them had burnt out
por
Exibir mais 66 comentários
Adicionar um comentário
24 respostas
Solução escolhida
In most cases, you can solve these problems by putting the phone into recovery mode and restoring it from backup. To do that, follow these instructions:
1. Connect the iPhone's USB cable to your computer, but not your iPhone.
2. Turn your iPhone off. If the phone won't turn off in the traditional manner, just keep holding the buttons until the screen goes dark.
3. Once you've turned the device off, press the home button on the face of the device and plug in the USB cable to the device's dock connector.
4. When it turns on, keep pressing the home button until the iTunes logo appears on the screen.
5. You'll know the phone is now in recovery mode because a window in iTunes will tell you.
6. You can then start the restore process by clicking the "Restore" button in the iTunes window.
Esta resposta foi útil?
Pontuação 173
102 comentários:
I think it is one of the most important info for me.
por
thank you, it works :)
por
bingo..!!!
its bang on..it works...
por
Thanks ya.. it worked
por
my phone wont even turn on when its plugged in to the computer only a wall outlet
por
Exibir mais 97 comentários
In order to get the iPhone out of the Apple logo loop, you can try DFU mode as below:
Hold down the Home and Power buttons at the same time for 10 seconds. Then, release the Power button while holding the Home button for another 15 seconds.
Pontuação 44
38 comentários:
thankyou so much this really helped :D
por
My phone won't turn on at all now :/
por
just like hannah my phone wont turn on at all now either after doing this??
por
if anyone does see this, mine goes to charger cable pointed to itunes on screen.
if this happens to you, connect it to you laptop to recover and restore your iphone.
por
i try and try but it says its going to reastore it but it just goes back to the apple logo again and does the loop and stays like that
por
Exibir mais 33 comentários
This article might help
Have you tried this with another usb cable? The cable might be damaged. It can also be the battery not charging. Try cleaning out the data port to make sure that it has a good connection with the usb cable.
The fact that it won't stay on is troubling. I think you have to fix this problem first before you try to restore it.
Pontuação 32
1 comentário:
I Think You Might Wanna Reset The settings Checkout https://goo.gl/8QduzX
por
Bradley Kirwan, start by replacing the battery. If that does not yield any results, I'd consider a new dock connector. After that, you are looking at power management circuitry issues, on the logic board.
Pontuação 14
4 comentários:
hey guys im having a problem my iphone 5s died and i plugged it in and it went to the boot logo and it just stays on the logo i hold power and home torestart it amd it just stays on the logo please help
por
did you ever find the solution to this? It's happened to me with my 5c and I don't know what to do
por
por
This happened to me too. I did the whol hold down power and home button for 10 seconds then release the power buttom and just hold down the home button for a urther 15 and eventually it turned on. Like 20 seconds later though so weird, and it was fully charged.
5c's suck
por
By the sounds of things sounds like you need a new battery, this should solve the issue. :-)
Pontuação 11
8 comentários:
Thank you Ged, your method worked.
por
No problem! :)
por
hie mine just flashes the logo only when connected to the charger,iphone 5
por
This means it's not seeing your battery, replace battery, if that doesn't solve it, possibly faulty replacement, if not, check battery connector for damage and surrounding components.
por
I tried almost all the methods above that didn't require money or prying open the case. I ended up getting an iPhone 5 battery replacement kit from iFixit.com, not even realizing they were the same folks as this blog I'd followed to try and fix my issue. The replacement battery worked right away for me. Had to put in DFU mode then restore, but it worked after trying everything else. Thanks to everyone who posted solutions!
por
Exibir mais 3 comentários
Thanks to the suggestions here, I was able to fix my wife's "broken" iPhone 5. She recently dropped it while in a case. It didn't crack or suffer any obvious damage, but it refused to turn on without the charger connected. We tried to do the iTunes update and restore but neither worked. It would go to the Recovery screen but never beyond.
After reading about broken batteries, I opened it up and discovered... bad quality control from the manufacturer. It was missing 2 screws from the upper cable bracket, but more importantly, it was missing the entire bracket that secures the battery connector in place. This cable had popped out when it hit the floor so it wouldn't power up on its own. I reconnected it and reassembled it and it came up right away.
After doing an update through iTunes, everything was back to normal. Now, I am a hero! The battery idea made sense, but I expected to see it broken. Unplugged was easier to fix and cheaper.
Pontuação 10
Replace with new battery and dock connector and restore it will work
Pontuação 10
I had this problem with my iPhone 5s. I placed the phone in recovery mode by syncing it to a computer through a USB cable while holding down the home button. That broke the vicious cycle. (I did not let the recovery process continue because I didn't let iTunes open). I let it charge for a bit, and the next time I plugged it into the charger, it was able to charge normally. I did not need to recover my phone.
Pontuação 6
I had a iPhone 6 that I I left outside and it got rained on...
I let it dry completely but it keeps on showing the apple symbol over and over again,I fully cleaned the mother board with rubbing alcohol,do you think the battery is the problem?
Pontuação 5
EXACT same problem here. bradley. when you say "recovery mode", do you mean that you get a screen that has an image of cable and a url a top that says something like "www.apple.com/support"? sure i've got this....while plugged into the wall connector, but immediately after i unplug to transfer to computer the phone powers off. useless.
i was told the phone was 'dropped' hmmm...now the phone just goes through a continuous loop of of apple logo, black screen, and sometimes a flash of a solid red screen.
the phone will not loop if connected to computer through usb...it just basically is dead. well sometimes it will give a glimmer of hope when connected to computer, such as going through the logo, black screen sequence once, but immediately shuts down.
basically it will not power up unless directly connected to a wall charger. none of the recovery boot up sequencing has been successful...and i've tried them all, multiple times. believe me, i have.
i'm guessing the it could be a battery issue, or circuitry. seems like my software troubleshooting is not working, so time to investigate hardware issues.
what tools do i need to crack this little open?
Pontuação 1
2 comentários:
Hello, I had this problem where it was stuck in a bootloop only when plugged into a wall outlet but suddenly shut off after unplugging. I solved it by taking the screen off and unplugging the battery for 10-15 seconds. Plugged into the computer and BAM it worked. :) Try this and let me know.
por
Hi, I have the same issue as sveet.vred...
por
I managed to get mine fixed by opening up the phone. Turns out, it was just the battery cable that came loose... It could also be the motherboard though, but mine was just the battery cable...
I suggest taking it to Apple to get them to open it up for you, or if you want to do it yourself, use patience and a really tiny screw-driver and a suction cup to pry the screen up. I decided that my phone was already screwed, it couldn't get any more screwed up anyway, so just opened it, and after reconnecting the loose cable, it works perfect again, so yay.
Pontuação 1
My iPhone 4s logo comes off and on when plugged to light and laptop, when you hold the home and power button it shows the connect to iTunes symbol but turns off immediately it's disconnected from power source hence it wont format properly, I have changed the battery, checked and made sure the battery connectors are in order. Please what can I do?
Pontuação 1
HI … if anybody can help..
after restarting iphone 6s , it does not load and is stuck on white screen black logo . (while staring blinks, as if loading , than stuck on white screen.).
no restart, no power button works, it is not recognized either if connecting to pc.
charging properly, and only turned of if buttery gets low.
any help will be so much appreciated.
i am left out of connection during this hard, quarantine time, no password, no data, no emails,.. no conection with my job..
thank you for in advance
Pontuação 1
https://www.youtube.com/watch?v=2jrI_Mn_...
Pontuação 0
Heres how I managed to fix my iphone 4.
My problem was the same. Phone would restart again and again from apple logo. It wouldnt move further.
I tried restarting in DFU mode, tried to update and restore. But phone would keep restarting from apple logo mode..
I doubted it might be some battery problem or some hardware problem. So I opened the phone, I came to know that the one who opened the phone b4 me dint put the screws in connector of battery. So it was loose. So I manage to tighten it and tried to update and restore.
Bingo, that was the issue. The connector was loose so it just wouldnt move further. Now phone is installing the software.
Problem solved.
Pontuação 0
I have had the same problem, and it turned out that my battery cable was not connected.
I lost my battery cable-metal cover and i dropped my iphone. I think that what caused it to disconnect.
So if you had your phone opened previously or replaced anything like the screen or the battery or anything by yourself or by someone else, you may want to check on your cables again.
Pontuação 0
Hello guys my iPhone 4 even after I left it on charge all night still indicates low battery so I can't get it through those processes. What should I do?
Pontuação 0
I met the same problem. And I fixed it by entering the DFU mode
Pontuação 0
Usually battery replace and restore in DFU works well.
Pontuação 0
Hi Guys!
Here’s what i did. if your kinda tech guy dismantle your ipad 1 then once then on the battery remove the black tape cover of the battery (just the top part of left side battery.. then there will be two terminal (soldered) right terminal is negative right terminal is positive.
Now this is the good part. if you guys have a defective ipad/android charging cable, cut it at the tip to expose the wires and choose of course the positive and the negative one and directly connect it to the battery terminal…
My Ipad is now working again..
Hope it work to all of you.
Pontuação 0
Iphone 6s stuck on logo when starting up. How do I reset it if my home button is boken
Pontuação 0
I have a used iPhone 5 and it loops the Apple logo and I don’t have a computer to get on iTunes. It only shows life when connected to the charger and I don’t think I’ll have enough to get it fixed. What can I do?
Pontuação 0
what about data? that’s critically important. (no back up).
unable to by a new one next 2 weeks - all shops are closed at y current location. included online shops and apple service centers ,
my current order for new mac (from US store), is expected to arrive in a week, and i can not connect to monitor/ see etc..
they already lost 1st delivery, and still no money back.
desperate to fix it :(
Pontuação 0
It means it can no longer update and you need a 6 or higher. so basically get a new phone.
Pontuação -1
2 comentários:
its an iPhone 7 though
por
could it still di it on an iPhone 7
por
Adicionar a sua resposta
Bradley Kirwan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 34
Últimos 30 dias: 160
Ao todo: 1,952,273
