Upgrading RAM from 512 to 1G
I will be changing my RAM from 512 to 1G prior to installing Leopard.
Do I need to do anything special besides just changing the stick on the first startup?
Esta é uma boa pergunta?
No the computer should see the new memory on startup and be good. Just be careful to select the proper ram for your computer. I am including links for replacing the memory and for the memory itself is case you don't have them. Good luck with your project. Ralph
Mac mini (PowerPC) RAM Replacement
[produto vinculado ausente ou desativado: IF111-035]
Esta resposta foi útil?
Thank-you Ralf. I will give it a try this weekend.
Another question: I will purchase a wrist stap on the way home. Where should it be connected to?
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 1,282
