Ir para o conteúdo principal
Need a little advice on how to prevent static build up
I have never worked on a computer before and friend told me not to work on it while standing on carpet because of static. Is this true? If so what is the best way to avoid frying my motherboard with static besides working on a tile floor?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
You can build up a static charge wearing almost anything. ESD (Electrostatic discharge) 1/10 the amount of a felt shock can destroy RAM and other electronic components. If your wall jacks are grounded you can discharge yourself when you sit down. Reach over and touch the center screw of the plate. If you're still worried you can buy a wrist grounding strap that plugs into the wall for under $5.00 at your local Radio Shack.
Esta resposta foi útil?
Pontuação 5
2 comentários:
Good answer +1
por
Nice answer, good to know this. ++
por
Adicionar a sua resposta
Nathaniel Akers será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 3,577
