Ir para o conteúdo principal
Support and repair information for laptops made by Samsung.
345 Perguntas Visualizar todos
Pergunta encerrada
Samsung Laptop R530 hard drive enclosure requirements
Hi. Please can you tell me what spec sata hard drive enclosure I would need for samsung R530?
As laptop stopped working and I don't want to lose photos and files.
Not a tech person and don't know if need 2.5 or 3.5 inch and if needs to be USB 2 or 3?!
Thanks
Update
Ok - I purchased the below product
http://www.amazon.co.uk/Bipra-SATA-Adapt...
Hooked it all up but my drive shows no files and 100% free space.
Thinking the drive may be damaged and files/photos etc non recoverable.......
Esta é uma boa pergunta?
Pontuação 0
4 comentários
Do you just want to transfer the data or actually have an external for storage?
por
Hi thanks for your reply. Just want to transfer to a new laptop. Thanks
por
Brilliant! Thank you all
por
por
Adicionar um comentário
2 respostas
Solução escolhida
Roger, something like this will work for you Universal Drive Adapter
Imagem de Universal Drive Adapter
Produto
$24.99
Esta resposta foi útil?
Pontuação 1
Thanks for all the advice. I have ordered a drive adapter so hopefully this will work and the HD is not damaged and data can be copied.
I did press F8 on the laptop to see if it would go to a recovery page where I might be able to restore to when it was last working. Must admit dont know what I am doing as I am useless with comps.
When I did this it took me to a Samsung Recovery 4 programme but it got stuck on 'please wait' - Do you think this means no data got wiped and it just failed (I switched laptop off after realising it was just stuck) as I am worried data may have been deleted via this recovery and the adapter will no longer be an option!
Hoping the please wait meant it failed to load, just as the laptop is failing to load pass the windows boot up screen.
Thanks.
Pontuação 0
3 comentários:
Usually the recovery programs do not override your data. Those programs in general only focus on the OS and do not reformat the drive. So your data " should" be okay.
por
Brill - Thanks Oldturkey.
por
you are welcome. Best of luck to you.
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 726
