Ir para o conteúdo principal
The Samsung Brightside features a 3.1-inch touch screen and slide-out QWERTY keyboard.
21 Perguntas Visualizar todos
Pergunta encerrada
still works but it has blackdots all over the screen
i just left my phone out in the rain and it wass out there for like 5 hours and i didnt know it was there when i found it it still works but it has blackdots all over the screen and my battery wont hold the charge and when i slide it open it shuts off! HELP I DOTN KNOW WHAT TO DO HOW DO I FIX IT ????
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Well Nikki, you should start by making a new post not posting in an old one. Second, what type of phone is it? and third, dry it off using a hairdryer or by leaving it in rice for a view hours to days. It is important that you do not try to turn it on before it is dry.
por
Adicionar um comentário
1 resposta
Solução escolhida
Nikki Demmer, just like Alex suggest, the very first thing you want to do is to no longer try to turn your phone on. The second thing you want to do is to clean your phone. If you do not clean it properly, you are running risk of having corrosion damage in the near future. Disassemble your phone completely and clean everything, especially the logic board, connectors and cable ends with 90%+ isopropyl alcohol. Use a soft brush to gently clean every "nook and cranny". Check your board for any missing or burned components. After that replace the battery. Re-assemble your phone and re-evaluate. Rice is a great first aid but it will not prevent corrosion nor repair your phone. If you still have a totally blank screen after that, it is possible that it is A: a bad LCD backlight (replace the LCD) or B: a short on the circuitry on the logic board. Let us know what you find. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 309
