Ir para o conteúdo principal
Pergunta encerrada
Lock Button slowly not responding
The Lock Button on my iPhone 5 is starting to slowly not response when I push it. I've read it's due to manufacturing defect. Unfortunately, I'm guessing my phone is now past the limited warranty period (which I'm confirming on Monday.)
My question is can it be repaired using the iPhone 5 Power Button Replacement Guide or not?
Thanks!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Thanks, Tom Chai. I completed the "Audio Control and Power Button Cable" guide and it solved my problem. See: iPhone 5 Audio Control and Power Button Cable Replacement
por
Adicionar um comentário
3 respostas
Solução escolhida
No. The correct one is "Audio Control and Power Button Cable". The power button is just a piece of metal that pushes the actual switch underneath it.
Esta resposta foi útil?
Pontuação 1
trocar o midi flex do botão de bloqueio de seu iPhone 5
Pontuação 0
I have to depress the power/lock button on my iPhone 5 at the far left to make it connect. Do you think a new cable is needed or should I try to run through the steps of replacing the plastic button to see if there is any dirt preventing a solid connection?
Thanks!
Pontuação 0
2 comentários:
new cable will solve the problem. apple made a low quality cable on this phone. very common issue
por
Thanks Vlad, I'll give this repair a shot.
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,320
