Ir para o conteúdo principal
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Perguntas Visualizar todos
Pergunta encerrada
If the io is defect will it prevent booting
My MBA is completely dead. Won't charge. Only a very dim green light. Pressing the start start button does not have any effect. The I / O board, if thats defect, can it course this situation or is the mainboard broken?
No liquid or bumps.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Thanks for your reply. I'll will have a closer look at the logic board.
por
Adicionar um comentário
2 respostas
Solução escolhida
Peter,
Given your problem I don't think your I/O cable is the problem. The power logic is part of the main logic board. It's more likely you have a bad logic board (cold solder joint).
Esta resposta foi útil?
Pontuação 2
Use a multimeter to test the output of the charger. What does the battery test button tell you? Professional serve people have a place in life too. Even they might have a tough time with this one.
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 133
