Ir para o conteúdo principal
How do I replace my head phone jack?
I Have replaced the headphones, and no matter what I connect it too it does this same thing.
I will get either no sound or sound only from the right ear. If I wiggle the jack then I will get sound sometimes in the left, and if I hit it just right and don't move it I will have sound in both ears.
Please Help!
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
it is possible that there is a lint inside the headphone jack
but one of the soldering could also be weak - look at step 7 - there are 4 contacts - you need a soldering iron to fix this - resolder the 4 contacts and if you are lucky - it will work - if not - you have to change the headphone jack
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
shawn summey será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 5,395
