Ir para o conteúdo principal
Lançado em junho de 2012, modelo A1278. Processador Intel com Turbo Boost, até 512 MB DDR5 de RAM vídeo
Need help identifying a component on logic board
Hello,
I have a Macbook Pro a1278 i7 2.7GHZ which sustained a small liquid spill. I have found the part that is damaged but I don't know what is called.
Can someone please help me identify it ?? A part # would be very much appreciated.
I have attached a picture. It's not the "actual" board but it is identical.
I have circled it with red....just to the left of LVDS connector.
Thank you very much for your help.
Click below for the picture of it.
http://i875.photobucket.com/albums/ab313...
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Victor, that is reference designator U5400. It is a voltage output current shunt monitor made by TI, INA213 in a SC70 package. Get the datasheet from here and the part is available right here. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 0
2 comentários:
That's exactly what I was looking for, and Yes it did help tremendously. Thanks so much...oldturkey03 !! You're da man !!
por
Victor, thank you for accepting my answer. Best of luck to you and welcome to ifixit ;-)
por
Adicionar a sua resposta
Victor será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 236
