Ir para o conteúdo principal
Identificável pelo número de modelo S7562, o Galaxy S Duos é um smartphone com suporte a dois cartões SIM fabricado pela Samsung.
Power button not working GT-S7562
I've had !@#$ Phone for a year now and the first time when i had the problem with the power button it just would not turn off my phone, then I did some research on the web and and I came across a tip where you will take out the battery leave it like that for a day and then it will work. To my surprise it did work, for another three months and now it happened again and now I can't turn my phone on now for a week now.
I live in Kosovo and there are not Samsung service shops around.
My question is: Can it be fix? Where? ore any other suggestions will be greatly appreciated.
Valon.Hoxha@gmail.com
Esta é uma boa pergunta?
Pontuação 16
4 comentários
my samsung gts7562 wont power on after installing <[E610]unlock_1.0_signed.apk>on it.. i restarted and thats it..it dead..neither will it charge..plz help...
por
my samsung galaxy duo. the problem is the power button was kind of malfunction. it would not turn on
por
no warking
por
boss after 7562 complete flashing phone can not started
what can do
plz ans
por
Adicionar um comentário
4 respostas
Pergunta mais útil
change the battery ,get the another working battery because may be ur battery inside run out of charge .get any working battery and put it there it will work
Esta resposta foi útil?
Pontuação 4
Plug your phone in charger while pressing the middle button it would turn on. or press the side volume button it would turn o.
Pontuação 1
1 comentário:
volume botton not warking
por
side button off to directly switchoff
Pontuação 1
How to on the samsung gts7562 mobile without power button
Pontuação 0
Adicionar a sua resposta
Valon Hoxha será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 23
Ao todo: 25,732
