Ir para o conteúdo principal
Um tablet de 10,1 polegadas da Samsung com processador de 1,4 GHz, tela LCD de 1280x800 pixels e display multitoque de 149 ppi. O número de modelo do dispositivo é GT-N8013ZW. Lançado em agosto de 2012, o reparo deste dispositivo é simples.
Display - Screen colors go fussy
The display screen on my Samsung Galaxy Note 10.0 note goes fussy and the screen does not always respond to touch. I don't know if it is the screen only or the digitizer. The tulips are my screensaver and what happens is that the edges of the tulips start becoming fussy and the colors start changing. Please let me know whether I should buy a new digitizer and if so please let me know how to install it.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
That sounds like the LCD. The digitizer wouldn't change any coloration. Also take in to consideration if you left this device in the direct sun for a long time or in a vehicle it may be a GPU overheating issue. If not. I'd say LCD. Just my opinion. Good luck.
Esta resposta foi útil?
Pontuação 0
3 comentários:
I had this same problem of fussy colors. I left it in my car facing the dun for long. How do I get my right colors back?
por Compartilhar
I need advice for my samsung note 10.1. Mostly fuzzy screen and blue shadding around pictures. My blue screen for the signing in to samsung is now green.
por Compartilhar
I am having similar problem as the last comment with my Note 10.1. The screen is mostly fuzzy with a royal blue color around pictures/objects on the screen. Can this be repaired? Grandma Sil
por Compartilhar
I faced the same problem before. I sent it for repair and the technician said it was due to a flex cable problem.
After replacement, it can be used as normal.
Pontuação 0
Adicionar a sua resposta
Julie Dobbs será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 2,739
