Ir para o conteúdo principal
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 Perguntas Visualizar todos
Pergunta encerrada
Why wiill it not boot after new digitizer fitted?
I have just replaced a digitizer front screen on a friends iPad 4.
It was working fine before I did this, the screen was just cracked.
Now I get [NAND] find flash media and keepout 601 physical block off set .... there are about 5 to 6 lines all starting with NAND, The Apple logo is in the centre of the screen.
The only way I can turn the machine off is holding down the home button and sleep bottom together.
Help! Many thanks Dan
Esta é uma boa pergunta?
Pontuação 0
1 comentário
check my answer below
por
Adicionar um comentário
3 respostas
Pergunta mais útil
we have the same problems please help!
Esta resposta foi útil?
Pontuação 1
1 comentário:
looook below!!!!!!
por
you want an answer ,??? no prob!! check the 3rd connector of camera disconnect it ,remove battery ,reassemble it again W/O THE CAMERA CONNECTOR IN !! and try
if still issue remains ---try a new lcd full set! and if its still with the nand error of kernel panic !!!
check the------------->>>> u2 chip!!!!!!!!!! and cover the whole board with tape so that there wont be any connection to the back lcd bezzel aluminium cover!!
http://i00.i.aliimg.com/img/pb/465/292/6...
Pontuação 0
Has anyone tried this fix from Masta at all and can you advise more on method and outcome please?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 386
