Ir para o conteúdo principal
Repair and support information for HP Laptops, designed for home and home office use.
1040 Perguntas Visualizar todos
Pergunta encerrada
My computer does not start
I have a HP Pavilion dv6-1006el. When I turn on the computer many times will not start. LEDs next to the keys and uppercase Slip flash. rarely leaves regularly. This happens both on battery power that network. thanks for the help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Check the RAM slots in this computer. The computer behaves like this when there are NO memory slots installed. Just as well it might behave this way if the RAM is of an incorrect type or if you have two sticks of different types. 2G and 4G for example, but keep in mind that if you have sticks with identical size but different speeds, this can also be incorrect. If the ram is identical one may be damaged, try one of the sticks at a time or try a different stick altogether.
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 90
