Ir para o conteúdo principal
O Palm Pre é um smartphone multimídia projetado e comercializado pela Palm, com uma tela tátil e teclado deslizante.
How do I replace Palm Pre Speaker?
Hi the speaker on my palm pre has blown twice now and I dont want to get another replacement phone, can I replace the current speaker with a different kind and isntall it my self? If so, would this be difficult to do ?
Patrick
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
4 respostas
Pergunta mais útil
replacing the speaker would be almost easy - but i have not seen any of the speakers on the net
the problem is, that the pre is to loud and kills the speaker - so i would use the warranty to get this problem fixed
Esta resposta foi útil?
Pontuação 2
2 comentários:
Markus,
I have found a different brand speaker which matches the measurements of the pre's original speaker, instead of getting another pre, I am going to change this over myself, no point getting another pre when the speaker will blow again. I will take some photos and place it on here for people who want to try this.
por Compartilhar
I understand that - here is the guide
por Compartilhar
I had the speakers on two pres go out within two weeks of getting the phones. The problem is the speaker grill is located directly above the speaker and offers little protection against foreign objects. We work in a metal fabrication are and both phones collected metal shavings on the speaker which shorted out the speaker. It can be prevented by placing scotch tape over the grill, but sound and volume quality will be effected.
Pontuação 1
I fixed this issue with in 2 min.
Take cotton Buds, correct the buds thickness to headphone socket. Spray any deodorant or Alcohol in the cotton. Insert and remove 5 to 10 times in the socket. wait for 2 min and play songs. now you will hear sound. Enjoy :)
Pontuação 0
The cotton bud and alcohol trick worked wonderfully for me. Thanks a million!
John
Pontuação 0
Adicionar a sua resposta
Patrick será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 12
Ao todo: 9,692
