Ir para o conteúdo principal
O Aspire 7741Z é um notebook da Acer com uma tela HD widescreen de 17,3 polegadas retroiluminada por LED.
Replacing internal hard drive
My external hard drive failed for the 3rd time so I would like to replace the actual internal hard drive. For this device, what type of hard drive should I buy? Is there limitations to the physical size/dimensions and hard disk capacity? What tools do I need to open and how do I go about replacing the hard drive?
Thanks in advance.
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Kat, great video on here http://www.youtube.com/watch?v=6k-FnZze3... It's a straight forward task, not to complicated. All you seem to need is a Phillips #1 or #0... remember that when you change the HDD, make a guide for the rest of us. Hope this helps, good luck.
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
IFIXIT doesn't currently have a repair guide for this model. It appears someone has started the guide but didn't get a chance to finish it {how about helping us out}. It's people like you that make IFIXIT what it is.
As to the tools you'll need looking at the other Acer guides it appears you'll only need a Phillips #00 Screwdriver. But until someone documents things you might get a surprise once you get inside. You might want to get the IFIXIT tool kit with the plastic sponger tools.
As far as the HD its' self, looking at a few parts suppliers you'll need a 2.5" 9.5 mm high SATA II HD.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Kat será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 1,907
