Ir para o conteúdo principal
Modelo A1286. Lançado em fevereiro de 2011 / Processador Intel Core i7 Quad-core de 2,0, 2,2 ou 2,3 GHz
Boot up after replacing hard drive
Just replaced hard drive on macbook and get question mark on screen. How do I reboot?
Esta é uma boa pergunta?
Pontuação 11
1 comentário
Do you know what operating system you had?
por
Adicionar um comentário
4 respostas
Solução escolhida
Hi michael. It sounds like the OS is missing from the hard drive. Is this a new hard drive? If so, you need to reinstall the OS. You should boot the MacBook holding option key down and reinstall your OS.
Esta resposta foi útil?
Pontuação 5
Hi,
As you have replaced the H.D.D you have to install OS in it as well try below steps to re install OS in your MAC.
Insert the install DVD, restart or force restart if you cannot do that otherwise by pressing power button 6 seconds until mac shuts down, then press it normally to start.
Immediately after chime, press option/alt key; wait 3-4 seconds, you should see the boot options, among these the DVD and the internal disk, Select DVD and continue.
Go on booting from the DVD and, after selecting the operating language .
Follow on screen instructions to install OS in your MAC, Finish installation and restart your MAC.
Good Luck.
Pontuação 0
1 comentário:
I did the same, but when it asks what disk i would like to install, no disck is available to select
por
hello, i have the same problem, but never apear the operating language selection menu. only appear when i dont have de HDD in my mac.
Pontuação 0
Sounds like you need to reinstall the operating system.
I would turn it on and as soon as it turns on try this:
1. Hold down the Command Key & the “R” key @ the same time. Wait till recovery mode shows up and follow the instructions from there on to install the new OS.
2. Hold Down the Command + Options + R Keys at the same time this is for Internet Recovery mode.
4. Try resetting your PRAM by pressing and holding the Command + Option + P and R keys right as you turn the computer on and wait for the computer to restart on its own and chime once again then let go.
Pontuação 0
Adicionar a sua resposta
michael será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Ao todo: 29,026
