Ir para o conteúdo principal
Processador Core Solo de 1,5, Core Duo de 1,66 ou 1,83, ou Core 2 Duo de 1,83 ou 2 GHz. Isto cobre os primeiros modelos de Mac mini baseados em Intel, de início de 2006 a meados de 2007.
No Sound from Mac Mini!
I have a new problem that involves no sound coming out of the Mac Mini's speakers. When i received my Mini from the seller there was a gap to the rear of the unit as the party before me did not reassembly the top cover all the way. I gave it back to have the cover fitted correctly and now after powering on the unit I recognise that there is no sound, and plugged in some external speakers and got sound for just about 2mins then a lot of static. I then purchease a putty knife filed the edges and opened the case, but I found nothing that seemed like it was out of placeso I reassembeled.
Any suggestions?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
4 respostas
Solução escolhida
sounds like a problem with the audio board
maybe you should open the mini again and look if there is something odd with the board or the connection
Esta resposta foi útil?
Pontuação 3
Pergunta mais útil
I had the same problem with a Core Solo machine. Turns out the people who installed some RAM (this was before I discovered ifixit) had not properly seated the ZIF cable in its socket.
Steps 7 and 8 in the Audio Board install (Substituição da placa de áudio do Mac mini modelo A1176) are where the solution lies.
There is a painted line on the ZIF cable. Before you close the cable lock, make sure the cable is fully inserted - the painted line will be about 1mm above and parallel to the top of the socket. Push down the clip and all should be well.
Pontuação 5
1 comentário:
this was it for me, SSD was installed by previous owner and the ZIF cable was re-seated BEHIND the actual connecter! Phew :)
por Compartilhar
I had the same problem with my MAC MINI A1176 Audio Board so instead of opening the case again I have scarified 1 USB socket and inserted a USB audio divice and it works just fine.
a internal can cost a 30 $ on eBAY but a USB dive can cost you 5 $.
Pontuação 2
Thanks Gary, this was exactly it!
Pontuação 1
Adicionar a sua resposta
Robert Antoine será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 34
Ao todo: 12,350
