Ir para o conteúdo principal
Line of laptop computers aimed at the small business market, designed to replace the Dimension line of laptop computers.
20 Perguntas Visualizar todos
blue veritical line on Vostro 1015 lcd screeen
blue veritical line on lcd screeen
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
The vertical strips are dead pixels. That being said a cable could be torn messed up inside your device and so on. Is this a tv a computer or what?
Esta resposta foi útil?
Pontuação 0
anusha, a single vertical line is usually caused by a TAB eror. Check your signal cables to make sure it is properly seated. If it is, the LCD needs to be replaced to get rid of that line. Hope this helps, good luck.
Pontuação 0
Adicionar a sua resposta
anusha será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 323
