MacBook Air 2013 to 2011 battery compatibility?
Hello everyone,
I have a mid-2011 macbook air that requires a battery replacement (it says service battery and its capacity has reduced to about 70%).
Now, its startled me that the new 2013 macbook air, which has a 7150mAh capacity battery is not compatible with the mid-2011 model according to ifixit.com.
I'm just finding it a bit difficult to understand why that may be the case, the capacity of my battery when it was new was 6700mAh and I thought that I would be able to replace it with the 2013 battery which is exactly the same physical size and shape..
What do you guys think? Am I missing something here? Could it be something to do with the CPU current?
Esta pergunta é pertinente?
There is often other things that make it not fit or work. In this case I suspect the dimension of the battery that's different.
por Dan
