Ir para o conteúdo principal
A Nikon D80 é uma câmera digital de 10,2 megapixels com lente intercambiável, lançada ao público em 2005. Ela é voltada para a fotografia e filmagem digital.
FULL message on LCD
I purchased a new Ultra SanDisk 64GB for an upcoming trip. I have formatted the disk, but the LCD on my D80 says "Full" and will not allow me to shoot. If I replace with the current 16 GB disk, everything works OK. What can I do?
Esta é uma boa pergunta?
Pontuação 5
9 comentários
Did you format your new card?
por Compartilhar
The following SD memory cards have been approved for use in the D80 digital SLR. All cards of the designated make and capacity can be used, regardless of speed."
Nikon 512MB, 1GB
SanDisk 64MB, 128MB, 256MB, 512MB, 1GB, 2GB1, 4GB2
Panasonic 64MB, 128MB, 256MB, 512MB, 1GB, 2GB1, 4GB2
Toshiba 64MB, 128MB, 256MB, 512MB, 1GB, 2GB1
All SD memory cards indicated above can be used regardless of their transfer speed.
Lexar Media
256 MB, 512 MB, 1 GB
Platinum II (60x) series: 512 MB, 1 GB
Professional (133x) series: 1 GB, 2 GB1
1 If the memory card will be used with a card reader or other device, the device must support 2-GB SD memory cards.
2 SDHC-compliant.
from https://support.nikonusa.com/app/answers...
So according to Nikon, even your 16GB should not be working;-) try to format and see what you come up with.
por Compartilhar
remove battery from camera and wait about 30 seconds then then replace and all should be ok
por Compartilhar
Thanks @james cleary, it worked.
por Compartilhar
I'm having the same problem, k have a SanDisk 64gb in my d80 and it's formatted to Fat32 and it still says full
por Compartilhar
Exibir mais 4 comentários
Adicionar um comentário
2 respostas
Pergunta mais útil
Max size of card is 32GB (SDHC)
read more at http://en.wikipedia.org/wiki/Secure_Digi...
Esta resposta foi útil?
Pontuação 3
There is a good chance the camera doesn't recognize that large of an SD card. Did you try creating a smaller partition on the card? Nikon may have a firmware update but that's an older camera so it may not support that large of a memory card.
Pontuação 1
2 comentários:
How might one do that?
por Compartilhar
How do I partition the SD Card?
por Compartilhar
Adicionar a sua resposta
Joseph Sharkey será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 53
Ao todo: 26,658
