Ir para o conteúdo principal
Model A1347. Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
Two SSD Drive Raid 0
Just wondering if it is possible to install 2 SSD into Mac Mini Late 2012 model and do a RAID 0 ?
I bought 2 kits from ebay and none of them able to detect the "Upper" SSD.
Is there any differences among those cables ?
Esta é uma boa pergunta?
Pontuação -1
2 comentários
There does appear to be an issue with a double SSD setup refer to this question: SSD will not show up after installing
por
As I expressed to Radjin someone with the setup needs to speak to Apple as it does appear the ML installer has an issue and I suspect the EFI firmware may as well here.
por
Adicionar um comentário
1 resposta
Solução escolhida
Apple does have a problem with both the Mountain Lion installer as well as within the systems BIOS (EFI).
Esta resposta foi útil?
Pontuação 1
4 comentários:
Is this an answer or a comment?
por
Answer per Apple - See other Answer for the background SSD will not show up after installing
por
After reading through all the info on the other question, I take it that the answer is "No" right now.
por
Yes, it's no for now.
por
Adicionar a sua resposta
Agustinus Harjono será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 2,416
