Ir para o conteúdo principal
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
How do I replace the docking connector?
Within the first 6 months I had trouble charging or transferring data, and now I need to tweak the connector continually to sustain a connection. I sent it in for servicing while warrantied and was told that there was no problem other than using the wrong (nexxtech) cable... but it just got worse.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
It seems you have to replace the note 2 charging port cable. Hope this tutorial video could help you. Good luck! http://www.youtube.com/watch?v=Opl0498DA...
Esta resposta foi útil?
Pontuação 0
1 comentário:
Sarah, careful with recommending this to often. It is included in every one of your answers. Just to make sure you are not spamming....
por
Adicionar a sua resposta
Grant será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 518
