Ir para o conteúdo principal
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Perguntas Visualizar todos
Volume button screw is stripped
I've been following the instructions to replace the rear panel on an iPhone 3G I'm experimenting with but when I came to remove the volume screws on the inside (4 of them) the middle one is well and truly stuck and I think I have now stripped the screw back through sheer frustration. Any hints?
VMT
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
small drill bit and drill the head off. then you can just pull the screw out with some little tweezers etc. there are other suggestions on here...just search for stripped screw. try the next size up PH or get a flathead instead?
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Aaron será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 80
