Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2376 Perguntas Visualizar todos
Just a quick battery adhesive question
My daughter's iPhone 4 battery has come loose.... It has timed itself "nicely" in a way as she needed a new one. I have ordered a new battery for her, but I was wondering whether the batteries themselves come with adhesive on them, or if that was only in the device itself?
Thanks in advance
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Solução escolhida
Most of the new replacement battery doesn't come with adhesive, and it is on the device, but you can ask the seller whether there is a adhesive on the battery. You can learn how to install the iPhone 4 battery from iPhone 4 Battery Replacement
Esta resposta foi útil?
Pontuação 0
1 comentário:
Accepted as was the first + answered the question perfectly.... Thanks! :)
por
Pergunta mais útil
You do not need adhesive. The battery area is just mm's larger than battery, so no adhesive is necessary. If iPhone battery came loose, the iPhone may have more serious issues than this?
Pontuação 2
1 comentário:
most time the battery just sticks to whatever adhesive is left on the mid frame. no need to waste money :-)
por
It is a separate piece of adhesive, you have to peel off the old one and apply new one
Pontuação 0
Adicionar a sua resposta
chumps52 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 105
