Ir para o conteúdo principal
Uma vasta variedade de guias de reparo para equipamentos eletrônicos, de sistemas de áudio doméstico e automotivo a calculadoras.
26421 Perguntas Visualizar todos
Can I charge a rechargable battery by keep put voltage?
it's a long story.
i heard 3.7V Li-Ion rechargable battery has 4.2V at full charged.
but i have a problem with making full charge detect and cutting off charge circuit in my situation.
so i think put 4.1V to the battery all the time makes charging but not over-charging it.
is this possible idea?
thanks in advance.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Anonymous, you can do that if you develop a proper circuit. You will need to provide a feedback circuit for the battery to manage the power to it. You can not just continuously supply 4.1V to the battery. I would suggest that you repair whatever device this goes with.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Most Li-ion chargers have two states of charge a low voltage and a high. Then often have a feedback circuit to know when the voltage & temperature has hit a threshold so as not to over charge the battery as doing so will cause it to explode and start a fire. I agree here with OT as you could damage the battery or worse yet start a fire.
por
Adicionar a sua resposta
Anonymous será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 81
