Ir para o conteúdo principal
changed lcd digitizer and data cable, still no fix for screen blackout
Hey guys,
I followed the manual to fix and change over the lcd digitizer and the display cable, but i still have the same problem. Whenever i set the display brightness past 4 levels, the screen will eventually go black and i will have to lower them to 1 then set it back under 4 levels. Would anyone know what else could be the problem? (i also fitted the cables in nicely, so i don't believe that it the cause).
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
The only thing left is your LCD I believe that the backlight is failing... replacing the backlight is a very advanced DIY project Replacing the entire LCD is difficult but not so nearly impossible for a DIYer.
Check on price and availability to determine if it's economically feasible to replace the screen.
If this Answer is helpful please remember to return and mark it Accepted.
Esta resposta foi útil?
Pontuação 1
4 comentários:
so what exactly would i be replacing? the lcd as a whole or a specific part of the lcd?
por
Easiest DIY fix - replace the LCD (backlight included). While it is possible to replace only the backlight it is a very advanced DIY project.
por
so just wondering where would i find out how to do the advanced way diy of the lcd? im sure i'd be capable if i had a guide to follow
por
Did you bother to look at the guide? There is a graphic on the right side just under the banner head.
por
Adicionar a sua resposta
James será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 199
